Civic 2016 CVT +6psi calibration
Civic 2016+ 1.5 Turbo
AtomCycom
Post by AtomCycom »
Hi admin, I'm from Malaysia and recently dynoed my civic 2016 turbo cvt with flashpro +6psi calibration. From the dyno, I'm only getting 195hp and 187ft-lb(254Nm) torque.
The value is lower compared to the advertised in the hondata website which stated 215hp and 220ft-lb(298Nm).
Why I'm not getting or close to the above mentioned value?
I'm using latest firmware of 2.7.4.
Kindly help.
Re: Civic 2016 CVT +6psi calibration
What was the difference between stock and your +6psi dyno? Do you have the chart images?
The dynos are not going to read the same so comparing the gains from stock would be the best way to compare.
Also be aware that after a reflash you need to run the engine under low-medium load for a while to bring the knock control down and achieve full power.
Jun43
Post by Jun43 »
Dynoing a CVT is tricky too
were you able to dyno the cvt in "3rd gear" below 3000rpm? the 1.5T makes peak TQ at 2800-3000rpm. which may expain why you TQ number is a bit lower if you couldn't get the RPM down low to dyno
chocoolatexenon
Post by chocoolatexenon »
Hi, Im new to this forum!
In response to the question asked by ATOM: I was very interested in finding out too. Could this be Hondata limiting the torque to 250Nm on the torque table in the calibrations for the +6psi tune map? I too would love to achieve 298Nm torque! Or could it really be possible for the car to bring the knock down and gain full power over a time period??
AtomCycom wrote: Wed Jun 21, 2017 11:33 pm Hi admin, I'm from Malaysia and recently dynoed my civic 2016 turbo cvt with flashpro +6psi calibration. From the dyno, I'm only getting 195hp and 187ft-lb(254Nm) torque.
Kindly help.
