Cam tables and Throttle control information
Civic 2016+ 1.5 Turbo
Garrett_si
Post by Garrett_si »
Hi, I didn't find where are the cam control tables, and I want to know why sometime the Pedal is on the floor but throttle is closing during pull?
thanks
Garrett_si
Re: Cam tables and Throttle control information
Here are the cal and datalog
Is this a CVT?
It is normal for the throttle plate to not match the throttle pedal. As long as the boost pressure matches the boost command the ECU may not always open the throttle fully.
Garrett_si
is a full Manual transmission.
Where are the cams tables?
It does not have cam tables like previous ECUs.
