2017 civic hatchback US FPM not reading ECU
Cervelo1
Post by Cervelo1 »
I just purchased FP new last week. Connected to laptop and OBD2 however the FPM did not read ECU. Please advise what is the issue?
Re: 2017 civic hatchback US FPM not reading ECU
What is the part number of your ECU?
Cervelo1
Post by Cervelo1 »
V 2.7.7.0
ECU 37820-5AN-L62
H366-102631
J3G
That ECU should be covered.
Can you plug the FlashPro into the car and laptop, switch on the ignition and then use 'Send support Information to Hondata' from the help menu?
Cervelo1
Post by Cervelo1 »
Thanks for the info. I dropped off the FP with the Hondata guys in Torrance today to check the unit. Ill keep you updated. Pick up scheduled for monday.
Cervelo1
Post by Cervelo1 »
I just p/u the FP from the guys today. It was a prob with the chip. All fixed and install went smooth. I also have the CARB version. However it did not have a map for a CAI. Is this correct?
Glad to hear it is fixed. The CARB version does not have calibrations for specific intakes (each one would involve a whole certification process). Most of the intakes run ok without specialized tuning.
Cervelo1
Post by Cervelo1 »
Thanks!
