Version 4.3.3
Monnoracing
Version 4.3.3
Post by Monnoracing »
Anyone else have issues with map sensor programming? If I run the stock map sensor and select stock map it is fine but if I try replacement map and select stock it is not right. I have a 4 bar and no matter what value I list it gives the same reading. Problem in the software?
Re: Version 4.3.3
You can't select stock if you have a replacement sensor that is not identical to stock.
