Closed Loop Target Lambda only works for v4?
akep
Post by akep »
I can't seem to get this v3 to change AFCMD from 14.7 to following Target Lambda tables, I just did it on 3 v4 ecus with success. Help file doesn't mention which version supports it, if different. Am I missing something or is it only a v4 thing?
Re: Closed Loop Target Lambda only works for v4?
Which target lambda tables - the ones in the calibration window or in the tables window?
akep
Post by akep »
the one from parameters > adv closed loop > target lambda low/high button - which brings up the table window for such
What wideband are you using?
akep
Post by akep »
PRB. if i turn it on, it will just correct to 14.7, if i turn it off it follows fuel map. AFCMD stays 14.7 no matter what i change it to.
Yes this is for the v4 only. It clearly states this in the parameters window.
