Honda S2000 KPro V4 ignition problem?
robert88
Post by robert88 »
Hello all !
I am writing about ECU and kpro system for Honda S2000.
Kpro connections to the computer works correctly.
The ECU is running correctly.(I think)
No check engine errors.
Upload calibratios works ok, but we have stragne situation with dataloging - please check movie:
https://www.youtube.com/watch?v=tM0STL7 ... e=youtu.be
During remodeling and measuring on dyno, we noticed that the system does not react to changing the ignition. Auto generally does not want to produce a power / torque that is adequate for this modifications.
The ignition was reversed by 8 degrees - the engine did not respond to such large changes, only when i change fuel value.The strangest thing is that the logs show a lower (correct) ignition value.
Another strange
The dealer in the phone told me about a case with kpro that had a problem with the firmware. Hondata did not report bugs but completely reacted to changes in calibration.
Feelings from drive are exactly like the ignition was frozen at one point.
Please help me on this.
Rob
Re: Honda S2000 KPro V4 ignition problem?
replied via email
