Australian Flashpro Euro Maps
GohardOzCu2
Post by GohardOzCu2 »
Hi all, just would like feedback on the Euro Ethanol maps.Can i use flex fuel in my CU2 using the Euro E34 map as a starter?
Re: Australian Flashpro Euro Maps
The FlashPro has no Flex Fuel sensor support. You would have to tune for the fuel in your tank at the time you are running it. If the ethanol content changes you will have to re-tune.
GohardOzCu2
Ok then,sounds like a long winded affair.The E15 Euro map would assimilate with E10 Fuel ( 95RON ) here in Australia?
If the ethanol content is always the same then it should not be an issue when properly tuned.
