KPRO RED FLASHING LIGHT
dre2fast
Post by dre2fast »
HELLO HOPEFULLY SOMEONE CAN HELP SERIAL NUMBER (45668) BRAND NEW KPRO V4 GOT STARIGHT FROM HONDATA 5/22/17 USE IT TWICE TO TURN ON CAR.... LAST SATURDAY I TURN ON THE CAR TO CALIBRATE TPS CAR RAN REALLY ROUGH AND TURNED OFF BY ITSELF WENT TO CHECK AND SAW RED FLASHING LIGHT NEVER DROVE CAR HAS ITS A PROJECT CAR SO IT SITS... CHECKED ALL MY GROUNDS ALL CONNECTOR TO ECU STILL NOTHING TRIED ON MY FRIENDS CARS STILL FLASHING RED LIGHT PUT HIS ON AND HIS CAR FIRED RIGHT BACK UP....... WHENEVER I OPEN UP KPRO I GET ALL KPRO INFO DRIVER INSTALLED ONLINE IGNITION OFF
Re: KPRO RED FLASHING LIGHT
Can you try removing the K-Pro board and trying it in your Friends ECU? This will tell us if it is the K-Pro or the ECU that might be the cause of the problem.
dre2fast
Post by dre2fast »
he doesn't want to go that far with his ecu
What vehicle is this being used in?
dre2fast
Post by dre2fast »
It's in a Honda crx
dre2fast
Post by dre2fast »
Also I cannot find kpro in device manager anymore
Send an email to support <at> Hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
dre2fast
Post by dre2fast »
Ok thanks I'm currently out of town I took a day off for this. so once I'm back hopefully we can get the problem solved ..
JDM FOOLAY
Post by JDM FOOLAY »
What did u do to get it fix I'm having same problem
DREAMBIG747
Post by DREAMBIG747 »
what happen i have same issue just received ecu and has red light flashing and fuel pump not pumping
