Ek 97 kpro o2 reading issue
Itrboost
Post by Itrboost »
My o2 on display at program showing 32:1-23:1 usually on idle is 23-27 when wot, it show 32 back up to 27-23, then let gas off showing 17 for few second then back to 23-27, check voltage in program showing 0.03v idle, on it around 0.32v roughly. 2nd o2 disable, and set on factory o2. No cel, heater and response is on.
Installed o2 sensor 234-9005 denso, wideband, using hybrid racing harness, plug it in, and check the wiring it's right.
Re: Ek 97 kpro o2 reading issue
Have you tried the ECU in a known good vehicle that everything is working?
Itrboost
Post by Itrboost »
No I haven't, other then rsx what else vehicle can use in it? Not alot ppl have rsx I know in the town I live in
