S300v3 issues
markstarscoobs
S300v3 issues
Post by markstarscoobs »
I have been having issues with my s300v3 i threw a solid cel light. so i started freaking out because i took the car for a drive the night before and it ran fine. no codes or lights. i figured the p28 might have fried so i bought a new s300 ready ecu. after swapping the s300 module over nothing has changed.
s300 serial# 374545
p28 ecu 2 one old and one new.
95 accord lx
h22a turbo
.57 trim
1120 fic injectors.
car start but dies unless you hold the throttle. i am wondering if its the injectors because after install the car started acting weird a few days later. it had erased my tune and wouldn't log anything. so i turned the on board logging off and figured i would just use my laptop. it ran fine until the day it stopped working with the logging off.
i will post the calibration and the log of it running rough when i get home
Re: S300v3 issues
What is the error code?
markstarscoobs
Re: S300v3 issues
it doesn't show one on the hondata app or when i plug into the usb. i tried to get the ecu to flash codes but nothing it stays a solid cel
Re: S300v3 issues
That is not a valid serial number.
What happens when you try to upload a calibration to the ECU?
markstarscoobs
Re: S300v3 issues
My bad the serial number on the unit is # 37545
It will upload the calibration to the ecu. i keep the software up to date on my hondata.
markstarscoobs
Re: S300v3 issues
I just went out to go test the uploading of calibrations and it uploads. after a few seconds the calibration is not showing yup. one of the LED lights is also flashing red.
Software version is V2.5.5
i pulled the unit out and connected it without the ecu it said the bluetooth hardware failed with a red X
Re: S300v3 issues
When you say the calibration is disappearing...where is it disappearing from?
markstarscoobs
Re: S300v3 issues
the calibration is on the s300 then i turn the key on to start the car and the calibration screen is blank.
markstarscoobs
Re: S300v3 issues
Thanks for the help SPunkster. I ended up Find the problem. My calibration was corrupted, i uploaded the older calibration and it fired right up.
