solenoid wiring
blacksi76
solenoid wiring
Post by blacksi76 »
I have a clutch flow controller installed that has an electronic line lock to activate it. I am going to wire it to the ecu via nit/aux 1 and use the parameters to activate it in first gear on launching via speed etc. I have a relay to wire in, is it the same wiring schematics used for the nitrous solenoid? Thanks
Re: solenoid wiring
Without more details of this line locker it is really hard to say.
blacksi76
Re: solenoid wiring
Post by blacksi76 »
Here's the link to the actual one
http://www.biondoracing.com/product/LL.html
Re: solenoid wiring
Since there is no info on how to wire this or any specifics given on that page, it is hard to say how it should be wired exactly. You can try using the same instructions s the nitrous control and see if that works.
blacksi76
Re: solenoid wiring
Post by blacksi76 »
Here's the instructions that came with the solenoid
blacksi76
Re: solenoid wiring
Post by blacksi76 »
Is this correct?
Re: solenoid wiring
It should be wired exactly like the nitrous solenoid in the help file: http://www.hondata.com/help/smanager/ni ... ub=nitrous
blacksi76
Re: solenoid wiring
Post by blacksi76 »
Excellent thanks, so 30 and 86 go to the same 12v switched source
Re: solenoid wiring
yes
blacksi76
Re: solenoid wiring
Post by blacksi76 »
Thanks again Spunkster!!! Always great service!!
iBoost
Re: solenoid wiring
Post by iBoost »
Is this the same as in KPRO?
I'm trying to do the exact same thing.
Re: solenoid wiring
