Gear sensor reading different gears through same pull.
Javcolin
Post by Javcolin »
Hi,
Car: Civic Si 2007 Supercharged tuned
Flash pro: latest firmware and latest version
I just experienced some weird stuff,
My car has been running great, fully tuned, but just today, I was going to do a pull so i can start spraying some Nos. but the car acted weird, as i floored the gas pedal, gauge revs needle went almost immediately to 7000 rpm's but war was not making any power suddenly rpms dropped and car was able to move fwd.
Acted like it was spinning and had no traction and suddenly got traction and hooks moving fwd, but actually wasn't spinning at all, just reved the hell without moving, and No, it is not the clutch, or clutch disk, both of them was working good a day ago.
One thing I noticed when review the logs, is that the gear position sensor was reading changes in gear, but i was always on 3rd gear, you can see that goes from 3rd to 2nd gear then 1st, stays in 1st then shift to 2nd then to 3rd, and other log, goes through all 6 gears, but i'm not shifting form 3rd at all.
would the gear position sensor could be causing that the car is not making any power and then kind of makes power thus moving fwd? is like revs but doesn't move then out of a sudden moves fwd.
Thanks in advance
Re: Gear sensor reading different gears through same pull.
Javcolin
Post by Javcolin »
Hi Spunkster,
Software version is. 2.7.9.0
Let me know
Update to 2.8.0.0
Javcolin
Post by Javcolin »
Ok,
Will do, and update once I do a 3rd gear pull,
Javcolin
Post by Javcolin »
Well,
I re-upload the map Using latest software version 2.8.0 and the issue was corrected,
Thanks a lot
