B16A with TODA stroker kit
bacsidoan
Post by bacsidoan »
I'm currently running a USDM CRX Si 1991 with JDM B16A (1st gen), P30 ECU, OBD0 to OBD1 conversion. I'm considering using the TODA stroker kit (Part Num: 13000-B16-001) to increase the displacement to 1820 cc. Is it possible to manage the engine with the S300 Hondata. If so what do I have to do?
Re: B16A with TODA stroker kit
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s300 ( https://www.hondata.com/index.php?_route_=s300 ).
