S2000 kpro a26 Power steering
RAIN H8R
Post by RAIN H8R »
The electronic power steering module on 00-05 S2000s sends a signal to the engine ecu via A26.
Is this function supported with kpro?
Re: S2000 kpro a26 Power steering
Yes it is
RAIN H8R
Post by RAIN H8R »
Thank you. Ive been using a26 for a datalog switch for years. My steering rack has failed, and Im looking to change pins due to the failure.
No other option on the manual datalog switch drop box will work for an S2000.
PSP is needed for the electric rack
SCS is needed for reading codes for SRS and EPS
Brake switch, only option but not sure it would be a good idea, not sure how this circuit effects anything
VTP Used for AC switch.
Any ideas?
Brake switch will not effect anything else.
RAIN H8R
Post by RAIN H8R »
I will do that. Thank you
margraz
Post by margraz »
I have a problem with a26 signal …
Is 0 volt straight steering and ok
But when steering i see in multimeter only 52 millivolt
And EPS run in safe mode (only 30% power steering )
I don’t have any dtc in EPS system …
You have a solution for this ?
It is a rare problem i think ..
Thanks for all
What is the serial number on the K-Pro board inside the ECU?
margraz
Post by margraz »
I only have OEM ecu I resolve it with kpro?
If you do not have a K-Pro then you will need to contact Honda for assistance with resolving this issue.
