kpro4 - closed loop on external wideband
eTiLiKo
Post by eTiLiKo »
Hi,
I'm trying to set the closed loop lambda using an AEM 30-0300 connected on analog inout on a Kpro4. K manager 4.3.3.0
First of all I set the analog inuput, see the attached image.
Than under closed loop operation I set external wideband but the dropdown menu doesn't give me any option to select.
If I select as a conversion one of the preset wideband it works. In my case seems that 30-0300 and 30-2310 conversion is the same, but I think that it must be corrected, to use the wideband input also with custom conversion.
fonzeka
Re: kpro4 - closed loop on external wideband
Post by fonzeka »
You can't run closed loop from a custom input, not sure why but hopefully Hondata will support this in the future or ad more presets.
