Stock Calibrations
musicman1488
Stock Calibrations
Post by musicman1488 »
Hi can anyone tell me if the stock B16A calibration in SManager is identical to the stock B16A calibration on the ROM of the ecu? Just the car runs as normal with the S300 removed but when i install the S300 and load the stock B16A calibration onto it the rev's fluctuate between 2,000 and 3,000 rpm on light throttle.
Re: Stock Calibrations
Have you tried calibrating the TPS?
musicman1488
Hi Spunkster sorry for the late reply i will try this today thanks. Also i have a JDM P30 ecu is there a way to remove the standard knock sensor board?
You should not remove it. Just disable knock in the calibration instead.
