PRC TO PRB CONVERT
dc5itr01
PRC TO PRB CONVERT
Post by dc5itr01 »
Hi,
I am currently using a PRC kpro in a DC5R. Jap spec.
I have a PRB ecu that i want make use of because i need the extra outputs. Pic attached.
Swapping the kpro board is the first issue. Will it work 100%?
Are the pinouts the same for prc and prb?
Prc uses cable throttle. Prb using ETB. Anything i need to do here? Would like to keep cable throttle.
Prc has no immobiliser. Prb does. Can i just disable this in kpro?
Thanks in advance.
dc5itr01
Re: PRC TO PRB CONVERT
Post by dc5itr01 »
Anyone please?
There is nothing you need to change for this.
