FlashProManager 2.8.3
Changes from 2.8.2.0:
  • FlashPro firmware updated to version 121
  • [2017 CRV] Added support for 5PA-C65 Canada
  • [2016-2017 Turbo Civic] Added boost by gear limit table and added support for 5AW-T51 - Turkey, 5AG-S83 - Australia, 5AA-Y52 - Middle East
  • [2016-2017 Turbo Civic - CVT] Added torque limit tables
  • [FN2] Fixed active tuning tables not downloading
Download here
mladjan
Re: FlashProManager 2.8.3
Post by mladjan »
Dis you fixed anything elese related to active tuning? Today I enabled it again and needed to disable it because while deiving it creates lean spots in lower rpms, usually noticable after shifts 1-2 and 2-3. I was usign 2.8.2 version, just saw your update.
Then increase your delay after injector restart. Also decrease the change per tuning cycle. You can also alter the minimum throttle to keep it from tuning at very low rpm/load combinations where the o2 is not responding quickly.
myuser
Post by myuser »
Please add the Maximum values for the Conditions in Active Tuning... this for FN2.
I was unable to perform Active Tuning as the Conditions stays yellow... is this related to Maximum limits?
Thanks.
"Conditions stays yellow" - what do you mean? Can you post a screenshot?
myuser
Post by myuser »
Hondata wrote: Sat Sep 16, 2017 9:29 am "Conditions stays yellow" - what do you mean? Can you post a screenshot?
Please check below... the TPS and ECT was changed and no Maximum values are presented (compared to Si).
Ok, got it. The yellow dot just means that the value has been changed. The maximum were not shown; we've fixed this for the next release.
myuser
Post by myuser »
Hondata wrote: Mon Sep 18, 2017 2:02 pm Ok, got it. The yellow dot just means that the value has been changed. The maximum were not shown; we've fixed this for the next release.
Just a little note:
The values stay yellow after the calibration is load and turn red after changing the values.
Thanks.
ridzuansaidi7767
Post by ridzuansaidi7767 »
Hi hondata. Do u still have v2.8.2 software. I need it coz I lost my laptop and now using new labtop I can't download my map in flashpro. I try today to install back the flashpro manager but it's already version 2.8.4. Please send me v 2.8.2 software. Thanks
You cannot backdate software. What is the exact problem you have? If you have lost he calibration then older software will not help.
ridzuansaidi7767
I need to download my calibration from the flashpro to use some new features. I didnt keep the file for this calibration. If i want to get back the file from tuner need to pay usd150. Each time update i need to pay for $150 if i need the calibration. I need the 2.8.2 so i can put it in my vault store. So next time i can download and use the updated features with the calibration. Thanks again for replying me
You don't need the same version of FlashProManager to download a calibration from a FlashPro. Your tuner may not have stored the calibration on the FlashPro.
