map fuel tables should i enable map to det WOT
brianandler
Post by brianandler »
tuning on MAP fuel tables should i enable MAP to determine WOT?
thanks
Re: map fuel tables should i enable map to det WOT
https://www.hondata.com/help/flashpro/c ... sed%2Bloop
WOT determination type
Either the MAP sensor or the throttle (TPS) can be used to determine when to switch from closed loop to open loop. For most vehicles MAP gives a more consistent switch point. For forced induction vehicles, MAP must be used.
