P0010 code on dash, but not on kpro
damiantuna
Post by damiantuna »
Hello all,
Im having a issue with my k24a2 swap in a 99 hatch. On the dashboard and when you plug a a code reader into the OBD2 port its giving me a p0010 code, but the code is not coming up on my kpro. not 100% sure on this but im assuming because of the code, my vtec does not pop either. Any idea of what could be the problem? Bad kpro? The kpro came with the car, as I bought it with the swap already done.
Thanks for any help
-Damian
Re: P0010 code on dash, but not on kpro
damiantuna
Spunkster wrote: Mon Sep 18, 2017 9:22 am What is the serial number that is on the K-Pro board inside the ECU?
Not sure exactly which one you are asking for but Ill list what I see:
05007850
37820-PND-A07
I hope this helps
I would recommend that you try this ECU on a known working vehicle to see if everything works correctly. To do this you will need to load the other person's calibration on to your ECU.
