Using Dakota SGI-5E to convert rear wheel speed signal
crucian
Post by crucian »
Hondata,
Can I use the SGI-5E to convert the rear wheel speed signal, that's feeding the traction control unit, to run the speedometer and ECU? I have the S300V3 in a 2000 Honda civic Si with stock cluster and P28ECU. Links to the device below.
http://www.dakotadigital.com/index.cfm/ ... prd126.htm
http://www.dakotadigital.com/pdf/SGI-5e.pdf
Is there any other way to besides using this device to use the rear speed sensors to provide input to the ECU and speedo?
Re: Using Dakota SGI-5E to convert rear wheel speed signal
I think this would be a question you should ask Dakota digital about since it is their device you are trying to use.
http://www.xenocron.com/xenocron-wheel- ... p-728.html
crucian
Post by crucian »
Can one of the square-wave-pulse output from the traction control device be used to run the speedometer or ECU?
No, they can't.
