Kpro v4 weird issue - Ignition stuck to ON
benjmd
Post by benjmd »
Good morning. I have a brandnew kpro v4 with weird issue. kpro shows ignition ON even when not plugged in the car. Sensors not being read. Car runs on limp mode but no engine error codes. I have video but dont know how to post. The rpm reading in the kpro is stuck at 5000 rpm even if car is not running. Currently car is in the car shop and would like some insights. By the way Im from the Philippines bought kpro from singapore. Please help me thank you
Re: Kpro v4 weird issue
Please post photos of the KPro and the installation, including the connections on the back of the ECU circuit board.
benjmd
Post by benjmd »
Please bear with me. This is the only video as of this time sent by my installer. Will try to extract more photos later. Please give me any insight. Thank you
benjmd
Re: Kpro v4 weird issue - Ignition stuck to ON
Post by benjmd »
Update:
Software updated to latest version. tested on other car with kpro and this is not working. car can run but on limp mode
Photos as requested
http://i1332.photobucket.com/albums/w60 ... pspv2j.jpg
http://i1332.photobucket.com/albums/w60 ... kzpxhj.jpg
http://i1332.photobucket.com/albums/w60 ... vd75wi.jpg
Photobucket links do not work.
