AIR / FUEL RATIO (AF) ERROR
dvergara
Post by dvergara »
Can you help me with this. I have 2 cars (civic if FA5 k20z3) that already had a very old tuning. I Download the latest update and upload my map .. after this the 2 cars have check engine . AIR / FUEL RATIO (AF) sensor (Sensor1) circuit out of range Hight
AUTO # 1
P1157
AUTO # 2
P1172
P2A00
Can you tell me if this is something I can adjust? or is a software problem. If I charge the old map the cars are no longer checked
dvergara
Post by dvergara »
AUTO # 1
P1157
AUTO # 2
P1172
P2A00
Re: AIR / FUEL RATIO (AF) ERROR
Can you post the calibrations you are using?
What is the exact year of these vehicles? Where are you located? Have you swapped ECUs?
dvergara
Post by dvergara »
Civic SI FA5 2009, The car was bought in the USA but we are in Panama.
Engine original stock .. header and exhaust skunk2. intake Hy, dense injectors 410cc
dvergara wrote: If I charge the old map the cars are no longer checked
I'd say the o2 sensor itself has died from vibration, but what do you mean here?
dvergara
Post by dvergara »
the problem is that if I put an old map the check ingen no longer appears
Can you post the old and new calibrations?
dvergara
Post by dvergara »
Here I send the two maps. I really appreciate your help
There's a lot of tuning differences between the calibrations (fuel trim, fuel tables, ignition, cam etc). I suspect that you fuel trims are getting very large with the new calibration and that is causing the error. Can you provide a datalog?
dvergara
Post by dvergara »
thanks for your help. Attached here 2 logs
It is running very, very rich. You need to tune the fuel tables. Also the WOT compensation are leaner than 12.5:1 so it is running closed loop the whole time, even WOT.
dvergara
Post by dvergara »
the oxygen sensor was damaged. Thank you
