Setting up Low/High boost control
blacksi76
Post by blacksi76 »
I'd like to set up the low/high boost control settings so I don't have to use two separate maps, does it have to be an external switch wired to the given ecu inputs? Can an analog or Digital input be used that plugs directly to the S300 version 3 board? Thanks
Re: Setting up Low/High boost control
It must be one of the ECU inputs for this. The analog and digital inputs on the s300 cannot be used for this.
