D16a6 turbo stock 240cc injector
EX-THIC
Post by EX-THIC »
Hey guys, I'm looking for a basemap for a d16a6 turbo. It has a 255lp Walbro fuel pump with stock si 240cc injector. I have a ebay t04e turbo kit with a turbosmart external dump with a 14psi wastegate spring. Please and thank you.
Jun43
Re: D16a6 turbo stock 240cc injector
Post by Jun43 »
you need more supporting mods.
240cc injectors is asking for trouble
EX-THIC
Post by EX-THIC »
Jun43 wrote: Thu Oct 05, 2017 7:03 pm you need more supporting mods.
I got rc 270 injector on the side I just need to put it on. I'm on a budget right now.
tolyan
Post by tolyan »
240 nozzles on the turbo is not enough
You will need a minimum of 440-550cc injectors. If you are on a budget, you should hold off installing the turbo until you can do it properly or you will damage your engine.
EX-THIC
Post by EX-THIC »
Planning on buying 550cc this weekend. Thanks for the help tho
