FlashProManager V2.8.5
V2.8.45 (19 October 2017)
  • FlashPro firmware updated to version 123
  • [2016-2017 Turbo Civic] Added support for 5AG-P71 - Indonesia
  • [2017 Civic Si] Added support for 5AM-K03 - South America
Download here
myuser
Re: FlashProManager V2.8.5
Post by myuser »
Hi,
Load Index
The column 10 and above, representing load, are with different values by accessing the Edit Load Index. Is this correct?
Example of Col.9, Col.10 and Col.20
Are the values in the edit correct or the table?
Datalog Compression
In case datalogs are big the compression fails.
File Size Example :
  • Datalog Time ~: 0:53:50.831s
  • FP Size - 21256311 bytes ~ 21.25 MB
  • Compressed in Disk - 500581997 bytes ~ 500.58 MB
  • Uncompressed in Disk - 500581997 bytes ~ 500.58 MB
  • Exported as CSV - 143387272 ~ 143.38 MB
Small datalog example:
  • Datalog Time ~: 0:01:06:099s
  • FP Size - 440887 bytes ~ 440.88 KB
  • Compressed in Disk - 110789 bytes ~ 110.78 KB
  • Uncompressed in Disk - 10367251 bytes ~ 10.36 MB
  • Exported as CSV - 2898831 ~ 2.76 MB
Is the data in FP memory raw or compressed?
Using the Delete All datalog function with big datalogs the values in Memory and
Recording values stay the same.
Load Index - your settings are set so that the columns above atmospheric show a relative pressure. The edit always uses absolute.
Datalog compression - at some point when compressing or decompressing both the compressed datalog and the uncompressed datalog are in memory at the same time, and under Windows it will run out of memory. In the install folder there is a 64 bit version of the application which you could try out as it will not have the same memory limit.
R-12914
Post by R-12914 »
On the 64-bit version, the flashpro help is crashing!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Yes, we are aware of that and have fixed it for the next release.
myuser
Post by myuser »
Hondata wrote: Tue Oct 24, 2017 4:01 pm Load Index - your settings are set so that the columns above atmospheric show a relative pressure. The edit always uses absolute.
Ok, thanks.
Please add the x64 version shortcut to the start menu in programs, or
set it by default in 64 bits systems.
Thanks again, and keep up the good work :)
x64 bit version has not been fully tested.
R-12914
Post by R-12914 »
With the 64 bit version, the datalogs are very, very big of size!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
With the new Version, the Datalogs are very big (1h = over 650 MB).
Not always, but from time to time!
Please fix this bug!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
janemar
Post by janemar »
Hi,
2017 Civic 1.5T Sedan International FP
5AG-Z82 Thailand / Philippines ECU
On old v2.8.3 and 2.8.4, I can hook up flashpro device anytime I want into car's OBD2 without any check engine light.
With the new v2.8.5, I need to hook up FP to OBD2 port first without turning ON ACC/Engine ON. If I hook up FP with engine running or in ON position, I will get and Electric power steerign fault(light flashes.) Need to turn off car and turn ON again to reset.
Hope you fix it on the next version.
Thanks!
