FlashPro cannot be locked to this Ecu
Civic 2016+ 1.5 Turbo
xrunner_08
Post by xrunner_08 »
Hi all!
I have a problem locking my FlashPro to my Ecu!
Data
Ecu:37820-5AA-X56
FlashPro Serial: FP-16CIVIC-L15T-200607
Message Problem:
The FlashPro cannot be locked to this ECU because the ECU contains an unrecognized calibration. If you report this message to Hondata please Include your calibration ID of "37805-5AA-X550"
Details:
When you connect and select the calibration on the FlashProManager it appears Civic 1.5t Mexico 6psi you loaded and when you try to lock the ECU it appears that message
On the FlashProManager I send the report problem with my email I hope to have an answer the soon as posible
If you can help me I,ll be very pleased
Re: FlashPro cannot be locked to this Ecu
We do not support that ECU. We will look into adding support, which may take a little while.
xrunner_08
But In the page it tells this:
Check ECU Compatibility
To ensure that you order the correct FlashPro we recommend that you check your ECU is supported.
ECU part number
37820-5AA-X56
Check ECU
The ECU part number is located on the ECU. You may need to remove a plastic cover in order to see the sticker containing the part number.
ECU part number 37820-5AA-X56 is supported by FlashPro 2016 Civic 1.5 Turbo
On the Link :https://www.hondata.com/products/flashpro
xrunner_08
Hondata wrote: Mon Oct 23, 2017 7:59 am We do not support that ECU. We will look into adding support, which may take a little while.
ECU part number
37820-5AA-X56
Check ECU
The web page looks up by the ECU part number, but sometimes the ECU calibration ID does not match the part number. It is a 2017 ECU; we'll look at adding support as soon as we can.
xrunner_08
Hondata wrote: Mon Oct 23, 2017 11:07 am The web page looks up by the ECU part number, but sometimes the ECU calibration ID does not match the part number. It is a 2017 ECU; we'll look at adding support as soon as we can.
Ok thank´s! For your support!:)
Just 1 more question!
What do you recommend me to do? Sell ​​it? or wait for the update or support???
if it's 1 month or 2 months I wait! But if it is 1 year I sell it!
Less than 1 month.
xrunner_08
Hondata wrote: Tue Oct 24, 2017 8:38 am Less than 1 month.
Thanks!!! You are the Best!! Now I added my Hondata to my Civic
