O2 Sensor
FlashPro questions & answers specific to the 2010 CR-Z (US, Euro & Asia)
Orim
O2 Sensor
Post by Orim »
Hello~
lot of people said they can use hondata flashpro to disable secondary O2 sensor.
i locked flashpro to my car, but not sure which option will do the job
should i disable EGR to make it work? but i through EGR is different than secondary O2 sensor.
i got a JDM CVT 2011 CRZ by the way.
please help.
Re: O2 Sensor
Parameters -> Closed Loop -> Secondary o2 sensor
There's no need to disable EGR.
Orim
Re: O2 Sensor
Post by Orim »
thanks your, i found it now.
also i saw the table list is different between one with other, is it mean some tuning only allowed at certain model?
like 2012 US MT have "Fuel Direct Ratio" but don't have "IMA torque request"
my JP CVT is another way around.
will you able to explain little bit more what "IMA torque request" please
I can understand "RPM", but which perimeter for "Load" are base on?
Because the index are between 0.898 to 1.000. i don't have clues which sensor it reading.
thanks agains
Re: O2 Sensor
"Fuel Direct Ratio" is for manifold wall deposit modeling - you only need it if you have a completely different manifold.
"IMA torque request" is the torque the engine requests from the IMA. Increasing at higher rpm will give a little more acceleration. Load index is engine load, but we are unsure of the exact units.
Matt Dex
Re: O2 Sensor
Post by Matt Dex »
Does the Asia crz have this IMA torque request? Where can we find it?
