stumbling at 4000rpm
rkhan
Post by rkhan »
Hi
Any help would be appreciated
I own a Honda Civic Type R EP3 with turbo and Hondata Kpro
When its cold it runs fine
When it warms up and I slowly accelerate to 4000 rpm the the engine stumble almost as a rev limiter (but rev limiter
set to 8000)
above 5000 rpm it is fine again
Re: stumbling at 4000rpm
Post your calibration and a datalog showing this issue.
rkhan
Post by rkhan »
Version KPro : 4.3.3.0
rkhan
Post by rkhan »
Problem
rkhan
Post by rkhan »
use of wideband input from ELD pin
voltage offset -0.27V
Spunkster wrote: Wed Nov 01, 2017 9:17 am What is the serial number that is on the K-Pro board inside the ECU?
rkhan
Post by rkhan »
Serial number is
05001175
PRA ECU
rkhan
Post by rkhan »
Any words of advice
Please see the information on acceleration smoothing retard at: http://www.hondata.com/help/kmanager/ge ... meters.htm
rkhan
Post by rkhan »
Would this cause the stumble always at 4000 rpm and only when engine warm ?
It might, try what it says in the help file.
rkhan
Post by rkhan »
will do
