Speedo output signal ?
L14MHA
Post by L14MHA »
Please can you let me know if there is a speed output signal available from a k Pro ?
I have recently had hondata TC installed and have lost the signal which previously came from the rear near side speed sensor.
The signal will feed into a lotus S2 “stack” dash.
Any advice is appreciated.
Thanks.
Re: Speedo output signal ?
The KPro does not have a speed output but the ECU does. Pin E25. Note that it is designed for a Civic/RSX cluster, so I don't know what the Stack requires. Also the TC has a pulse output based on the ABS input with a divisor.
