Using 2017 Civic 1.5 Flashpro for 2017 Civic si
azokie
Post by azokie »
I currently own a 2017 Civic HB which I have flashed the ECU using a FlashPro (2016+Civic 1.5T) and which is currently locked to that vehicle VIN. I plan on trading the HB for a Si. If I unlock the current Flaspro from the HB, can I use the same existing Flashpro on the Si, assuming I would need to change the base map and upload any current revisions?
Jun43
Re: Using 2017 Civic 1.5 Flashpro for 2017 Civic si
Post by Jun43 »
as long you unlock it before trading it in, you will be able to lock it onto the Si.
You will need to upload a Si calibration as the non Si calibration are not hte same
