Low volts
Unocam
Low volts
Post by Unocam »
Hello everyone i had a question that i can not find concerning my hondata s300 v2. My issues is according to smanager my battery is showing anywhere from 3 to 7 volts, from my battery i read 13 volts on my multimeter. I just had the battery and the alternator tested both are good. I also checked my grounds i have a total of 4 now. This issue is causing my car to just want to just die it might idle at less then 1000 rpms. And run really rich according to my wideband. Please help me id really appreciate the help.
Re: Low volts
Have you used a multimeter to check the voltage at the ECU pins?
Unocam
Re: Low volts
Post by Unocam »
Yeah it reads 12.4 on pin a25. I have a video of the smanager showing the battery voltage going crazy.
Unocam
Re: Low volts
Post by Unocam »
Re: Low volts
Can you post the calibration used as well as a datalog showing the issue.
Unocam
Re: Low volts
Post by Unocam »
Unocam
Re: Low volts
Post by Unocam »
I also just put the ecu in another car with a stock p28 calibration and got the same low voltage at 7.9 volts on smanager. Could the ecu board itself gone bad?
Re: Low volts
You should try your s300 in a different ECU to see if it is the ECU that is the problem. Also is J12 cut on the ECU?
Unocam
Re: Low volts
Post by Unocam »
That is my next step is to try another ecu. And yes j12 is removed. Thank you for all your help
Unocam
Re: Low volts
Post by Unocam »
Final update i replaced the ecu and had my s300 implanted in a new p28 and its fixed now i guess a capacitor or something went bad. They are 20 year old ecus
