Can you use 05-06 rsx spec kpro for a engine swap?
BooNzZz
Regarding kpro for 05-06 rsx, Is it possible?
Post by BooNzZz »
So the thing is, i have a kpro made for a 05-06 rsx. I heard they use high frequency signal for the speed sensor and possibly different ecu components. I was wondering how could i get it to work for a 1993 civic swap with the complete k20z1 swap using the 05-06 engine harness. Is it possible?
Re: Can you use 05-06 rsx spec kpro for a engine swap?
The K-Pro for 05-06 is designed to work only in an 05-06 RSX. It should not be used with engine swaps. Using it this way is at your own risk and we cannot assist with any issues you may run into. You would be much better off selling this to someone with an 05-06 RSX and getting a standard K-Pro for your vehicle.
