cannot upload map and now car not starting
windspot
Post by windspot »
Hi, i was trying to upload a map with the latest version but it was always telling me that cant upload map.
then i tried to erase security it says that happened succesfully and after i turned on the switch the immobilizer blinks the ecu lights up and the car not starting.... after several tries the car started but its not rev more than 3000rpm... please help!!!! civic ep3 type r 2004 european
Re: cannot upload map and now car not starting
After erasing the ECU you must upload a calibration to the ECU as it will not have a calibration on it.
windspot
Post by windspot »
I use the last version of your software. But it doesn’t work always fail to upload map and now no car...
What is the serial number of the KPro? What KManager version are you using?
windspot
Post by windspot »
947 and software version 4.3.4
When was the last time you were able to successfully upload to it?
windspot
Post by windspot »
I think april with version 3.3.1
What has changed on the vehicle since then? Have you had any other issues since then.
