Hondata TC and ABS Bosch M4
eliseeuropa
Post by eliseeuropa »
I have a question about the wiring for the TC when used with an ABS Bosch M4.
First, recap about the ABS Bosch M4: it is the ABS made for racing purpose from Bosch, programmable for the car, with a yaw sensor, and pressure sensor. The ABS is using active sensor.
Now, my question is how to connect the TC wheel speed input with the ABS. The ABS is supplied with hardness, and Bosch are quite sensitive about that, and it is specify to not cut it or splice it. A module is available to splice the sensor giving specific output for each wheels to the ECU as we are able to found on many cars with ECU with traction control.
I have two options, t first option is purchasing the module, which it make sense, and connect the output to the TC module. For this option, I just need the confirmation how to use the ABS output to connect the TC. This option is more expensive but fully safe for the ABS. The ABS have 5 wire output, 1 per wheel and the ground. The second option is splicing the wheel sensor and not meeting the Bosch recommendation. Again, the ABS is a racing ABS where the working zone is by far deeper than OEM ABS..
I did not see how to use the ABS output to drive the TC input.
Your support will be appreciate.
Marc
Re: Hondata TC and ABS Bosch M4
http://www.hondata.com/help/tractioncon ... wiring.htm
It would have to be wired according to the instructions in the help file. It is up to you if you need some other device as to not cut the wires.
eliseeuropa
On the help menu it is indicated to splice the wire between the ABS and the speed sensor.
My question is to confirm how to connect the the TC to the ABS output, I suppose it is just straight forward, please confirm. Please see attachment, with the outpiut interface. The link to the original document, page 49.
http://www.bosch-motorsport.de/content/ ... Manual.pdf
You will need to contact Bosch to find out which wire is which for each sensor then follow the instructions in our help file for active sensors.
eliseeuropa
It sound like I will need to do some trials... Bosch are answering not cut the hardness, and use the output from the optional speed sensor box. Typically, those outputs are going directly to the ECU like used on Motec as well as on the original ECU of the Lotus Elise/Exige. And they said you need to ask to the TC manufacturer if the TC can accept the output as is where the signal is voltage step. I feel that the output are acting like active sensor. For the wiring code and color, of course I can read the schematic as well as the TC help menu. Anyway, it is clear that you will not comment more than that. Sniff!
Well, what is the specification for the output from their speed box? Can't say anything without knowing that.
eliseeuropa
Based on what I can see on the manual, the output look like a straight +12 V, one wire per wheel with a one ground for all. I suppose it needs to be connected as active sensor with no ABS controller, with a 270 ohms. The switch turned "on" on the TC box.
This is my bet.
Do they give a waveform, amplitude and offset?
Chances are it will work ok. The TC input can be current sensitive (active sensors) or voltage sensitive (inductive sensors), and the TC input circuitry is self adjusting to different voltage levels.
eliseeuropa
Ok cool.
The waveform is a square pulse, and I suppose is 50/50. The voltage is just shown Ux V, but based on my experience on Bosch industrial stuff, it is probably the actual voltage at battery when the engine is running.
eliseeuropa
Change on my order from Bosch, I will receive the ABS M5 updated version which have output directly from the controller. Now, it is not clear at all for me.
I will copy the text from the manual.
Option 2: Wheel Speed TTL
ABS M5 delivers wheel speed Hall signals for FL, FR, RL and RR wheels as output.
Connector is available on wiring harness under Wheel Speed TTL for FL, FR, RL
and RR, see also Wiring Harness [} 48]. The following graphic shows the spec
as it is in the ECU. An example of the front left wheel is shown.
M5_TTL_connection.pdf
The reference ground is the GND_ECU
DC output current, Iout, 50 mA
H voltage level, Uout_high, no voltage indicated, but shown as ECU side with open collector
L Voltage, Uout_lowL 1.5 max from the controller, I <50 mA ECU side<
I don.'t know how to connect those signals, your help will be appreciated.
Marc
Open collector means that you will need a pull up resistor to +12V for each output. 470 ohms should keep the current below 50mA.
eliseeuropa
Please see my TC wiring diagram, and please confirm that it is switched the right way, and well done.
JR-005-45-1000_TC revA.pdf
Looks good.
eliseeuropa
I am taking few minutes to give a feed back. Everything works fine, the TC look like working pretty well on street. I did not tried it at the race track yet, but I will soon.
The only minor point is in order to communicate with the ABS, I need to remove the power from the TC and input. Not a major issue at all.
I am happy with the solution. And the ABS is working fine too.
Thanks for the feedback.
