Narrowband oxygen sensor
zerg336
Post by zerg336 »
While datalogging, I found my narrow o2 voltages read 3.0 volt.
I don't have wideband. Just stock narrow o2.
Narrow o2 voltage should be between 0-1v but mine reads more than 1v?
Is it okay just running like this?
Should I disable O2 heater since I'm running open loop?
Thank you.
Re: Narrowband oxygen sensor
The ECU pulls the o2 voltage to 3.8V when it is warming up. After a minute or so you can see the o2 voltage changing. For a turbo I would recommend a wideband.
G. Wiffington
Post by G. Wiffington »
Yes, get a wideband. Narrowband does not give an accurate reading for tuning. You need to see exactly what the air fuel ratio is to make accurate changes for tuning purposes.
