Fuel cut issue
switchleg
Fuel cut issue
Post by switchleg »
Hello,
I tried doing a pull tonight and the fuel cut out on my at 7300rpm. With the weather here being cold and the roads being icy I haven't had a chance to do many pulls in the high cam for a while though i believe this happened last week this same duty cycle and rpm. Looking at the datalog I cant see what could be the cause as my injectors were at 72% duty and pedal was at 101%. Any suggestions?
Also I have never experienced this issue in the past. I recently started using MAP to determine WOT and not sure if I have brought it to redline since.
Re: Fuel cut issue
Disable full throttle shift and see if that is the cause.
switchleg
Re: Fuel cut issue
Post by switchleg »
I haven't had time to test this but I am thinking this is the issue. I did have my foot resting on the clutch, maybe its a bit sensitive? Is there anyway to monitor the clutch sensor in flashpro?
switchleg
Re: Fuel cut issue
Post by switchleg »
Also note full throttle shifting has been enabled since I first installed flashpro 2 months ago and only since had this issue in the last two weeks. I enabled determine WOT via map sensor 3 weeks ago and tuned the low cam but not the high cam yet.
Re: Fuel cut issue
The clutch switch is just on/off, and does trigger with only light pressure on the clutch. I'd try disabling it and see if it is the problem.
