VSA and ABS Question
andyroosim
Post by andyroosim »
Okay, so I've read in related threads from the TSX sub-forum that VSA and ABS are not controlled by the ECU; and that they are indeed functioning together. As in if I were to turn off VSA using the button, ABS also turns off. Is this the same for the S2000?
Im assuming there is no way to disable VSA but keep ABS on using flashpro?
Thanks.
Re: VSA and ABS Question
ABS should only stop working if you completely unplug the ABS unit in the engine bay.
