02 ecu and 05 harness
Miguelmgm
Post by Miguelmgm »
I have'd a mistake and I'd connect 05 harness with 02 ecu with k pro now is red light all time and don't have communication with the laptop
Re: 02 ecu and 05 harness
What is the serial number that is on the K-Pro board inside the ECU.
What vehicle is this currently being used in?
Miguelmgm
Post by Miguelmgm »
Spunkster wrote: Thu Nov 30, 2017 11:17 am What is the serial number that is on the K-Pro board inside the ECU.
05003239 is te only one in the K-Pro it was for a swap and the harness is Acura 06
What is the part number on the outside of the ECU?
What vehicle is this being used in?
Miguelmgm
Post by Miguelmgm »
Spunkster wrote: Thu Nov 30, 2017 3:25 pm What is the part number on the outside of the ECU?
PRBA02 in Honda EG
We don't recommend using the 05 harness with engine swaps, but in an RSX if an 02-04 ECU is lugged into an 05-06 vehicle it will not damage the ECU in any way. What vehicle has the ECU been tested in after this was plugged in incorrectly?
Miguelmgm
Post by Miguelmgm »
Spunkster wrote: Thu Nov 30, 2017 4:25 pm We don't recommend using the 05 harness with engine swaps, but in an RSX if an 02-04 ECU is lugged into an 05-06 vehicle it will not damage the ECU in any way. What vehicle has the ECU been tested in after this was plugged in incorrectly?
Only in that one then the red light turn on and we don't have communication with the laptop
You should try the ECU in a known working vehicle that has the correct harness.
Miguelmgm
Post by Miguelmgm »
Spunkster wrote: Fri Dec 01, 2017 10:43 am You should try the ECU in a known working vehicle that has the correct harness.
Yes I tried in Acura RSX have kpro too and I change but de red light stay, whats the mining of red light but is not flashing
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
