Actual cam angle dont match ccam
luisae86
Post by luisae86 »
I need help pin pointing the issue any tips are welcomed.
The build is a k24a4/k20z1 head
Darton sleeved
Bc stage 2 cams with valve springs
Eagle rods
10:3:1 compression ratio wiseco pistons
RBC VTC
Holset hx40
Skunk2 ultra series intake 3.5l
1150cc grams injectors
PNF kpro v1
The issue is that once it goes higher than 5200rpm my cam angle changes to 60 and starts goin lean at 8psi
The cam angle tables are set to 0 degrees
And i cant select the lock cam feature because im using a pnf ecu? Any ideas of why it changes ?
Re: Actual cam angle dont match ccam
Without the calibration and a datalog showing the issue it is hard to say.
