injector voltage compensation
boostedtwo
Post by boostedtwo »
I need help figuring this out. I know the technical info on my injectors but i cannot figure out how to build the voltage compensation chart.
Gain: 0.12ms/MG
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 300KPa
Can someone please explain to me how I build my voltage compensation chart?
also another question, im running a b20vtec turbo, I have a aem uego wideband, I would only like to run this, is this possible or do i need to have a narrowband o2 going to the ecu still? I have already talked to a tuner about tuning my car but I would like to have these 2 things lined out before wasting his time.
Re: injector voltage compensation
You must enter the voltages vs. dead times into the table in the software. You may need to contact the manufacturer of the injectors if the information they have given you is not complete.
You can use a wideband input to run in closed loop. Select which input on the ECU you want to use on the closed loop advanced tab in Parameters. You should not use the D14 input as it cannot red the full voltage range.
