Car automaticly Shut down Every 2-3sec!
geekaz
Post by geekaz »
Rsx type s 2004 k20a2 // I need help please, after my OEM Camshaft installation the car start well and idle well but always dies automaticly every 2-3 sec, I think timing is good except the Pulse plate side im not sure about it, on kmanager Cam angle read -3 degrees everytime im giving gas I think thats not normal? the car is throwing 0 code. Im on kprov4
Re: Car automaticly Shut down Every 2-3sec!
Your timing marks do not line up. You should take this to someone experienced in working on K-Series engines.
geekaz
Post by geekaz »
you sure its not lined up?
geekaz
Post by geekaz »
and if its Off that is why my car keep shutting off? cause hes not throwing any code.
Paul Kennedy
Post by Paul Kennedy »
Check to see that your getting a map sensor reading ..
