Datalogging input shaft rpm
Korn4900
Post by Korn4900 »
I wanted to know if you can setup a sensor to data log the rpm on the transmission input shaft to determine if the clutch is slipping and mabye have a protection opting to let you know?
Re: Datalogging input shaft rpm
No, that is not possible.
Korn4900
Post by Korn4900 »
My kpro 4 has 20 inputs why can't you use one for that? I thought one is for a vss can't you sent that input?
