ignition problem?
nvusromero
ignition problem?
Post by nvusromero »
having issue with rpm fluctuating during full throttle 3rd gear pull . checked power and grounds, tried igniter and coil and checked timing belt tension all seem ok. any input would be appreciated . gsr block, skunk2 stage 1 tuner cams, itr usdm pistons, skunk2 intake manifold, alpha header and 70mm tb
Re: ignition problem?
If you have a wideband connected and the AF reading is correct then it looks like you are running too lean.
