Use of Flashpro for 2017 Civic 1.5L Turbo in Australia
Civic 2016+ 1.5 Turbo
d.sound
Post by d.sound »
Hi there,
I did read a response to a question on whether the Flashpro could be used to a Civic in Australia which was posted in Aug 2017. You had stated that at the time it was unavailable. Would the device be compatible for the Civic Turbo in Australia now?
Re: Use of Flashpro for 2017 Civic 1.5L Turbo in Australia
We support some of the Oz vehicles - it depends on the ECU calibration. If you get the ECU part number (37820-5xx-Qxx) then we can see if it is supported. Note that sometimes the ECU part number does not match the calibration so we can't say for certain if an ECU is supported, but almost any OBDII scanner can find the calibration ID which will give a definitive answer.
d.sound
Post by d.sound »
Where could I find the ECU part number?
d.sound
Post by d.sound »
Apologies. I found the ECU part number and it is 37820-5AG-S83. I believe this is supported? Thanks
Yes it is supported.
xenon04
Post by xenon04 »
Hi there,
I have EU 2017 civic 4 door 1.5T, manual transmission - engine code L15BB (134kW)
my ECU part number - 37820-5AW-G42 is not supported :(
is there any solution?
HONDA Civic Sedan 6MT 1.5 VTEC TURBO (L15BB 134kW)
Check back from time to time or follow the FlashPro release notes https://www.hondata.com/help/flashpro/whatsnewtopic.htm as we may support the ECU in the future.
xenon04
Post by xenon04 »
Hondata: OK, thanks for the link ;)
