FG2 with K20Z4 Engine( FN2 ) ???????
WUman
Post by WUman »
Hi
My friend have a FG2 wth a European K20Z4 engine.
Completly stock
So is it possible to run a FN2 Base map?
Or is it not possible to upload a FN2 map ona a FG2?
Re: FG2 with K20Z4 Engine( FN2 ) ???????
No, you can only load calibrations that are compatible with your ECU type. You will have to start with a basemap and tune from there.
typer86
Post by typer86 »
WUman wrote: Sat Jan 06, 2018 4:18 pm Hi
Completly stock
It is depending of the type of your ECU which you're running.
If you are running the RSP ECU from the FN2 you must use the FN2 calibration
If you are using the FD2 ECU use the FD2 calibration for tuning.
