Need to RMA the ECU =(
fhcampos
Post by fhcampos »
I have a 94 Civic DX with a Kswap. K20z3 engine and trans.
It uses a 05-06 RSX harness and a 2005-06 ECU with a kpro4 instaled. Kpro and ecu provided by hondata. Bought on No Limit Motorsport in NY.
The problem:
The VTC doesn´t work, the ecu doesn´t send the 12v signal to the solenoid. I have tried a bunch of things, but Im in Brazil and in here we dont have RSX parts.
The car runs perfect, all the other signal inputs are 100%.
The vtc never worked, from the box.
I have bought another ecu to try find the error, but its in the Micro and I dont have the tool to write it. I can send both ecu´s so U can make one out of 2.
Kpro serial>: 41830
ECU: 37820-PRB-305
2054-101543
THks
Re: Need to RMA the ECU =(
The K-Pro we offer for the 05-06 is for use only in an RSX and not with engine swaps. This is more than likely why you are having issues with the VTC.
an 05-06 stock ECU cannot use a K-Pro.
fhcampos
Post by fhcampos »
Ok, so how we solve this?
In the time of the purschase it has asked for a Kswap kpro4. We don´t have RSX´s in Brazil, so its kinda of impossible to ask for it.
Can you check the part number so we can be sure?
And the car runs perfect, flawless, just with the VTC stuck in 0.
You should discuss this with the dealer you purchased this from.
fhcampos
Post by fhcampos »
Is it possible to check the serial number?
And, if the aplication is wrong, exchange it? I can pay for the difference, just want to solve this.
This is something you will need to discuss with your dealer you purchased this from.
