Hondata Boost Solenoid capatability with Kraftwerkz Supercharger
Siknezz9409
Post by Siknezz9409 »
Hello, I am trying to finish my build and was wondering if the Hondata Four port Boost Solenoid can be used with the Kraftwerkz Supercharger on a Kseries motor using Kpro. If so, how would the vacuum lines be routed for it to function? Thanks
Re: Hondata Boost Solenoid capatability with Kraftwerkz Supercharger
It wouldn't really work as there is no wastegate on a centrifugal supercharger.
ef9b16a1
Post by ef9b16a1 »
you could use a wastegate in the intake pipe and control boost by the solenoid via ecu , it works
