PRA vs PRB ECU Differences
R23AOU
Post by R23AOU »
To try and cut a long story short, I'm in the closing stages of building a brand new Lotus Elise S1, the only items left over from the original car will be the front and rear clams, and the boot floor. Other than that, 100% new (bar a reconditioned Honda K20A2 engine upgrade).
The engine I have installed is a UK EP3 Civic engine, a PRA ECU with K100, narrowband O2, and stock engine loom.
In error I have purchased and installed a Rywire race chassis loom for US PRB ECU engines
https://www.rywire.com/product-p/k-sub-race.htm
thinking it would keep things simple and look neater than butchering a Civic loom and having relays etc. dotted about. I did note the comment about using an RSX Primary O2 sensor, but didn't pay it too much attention.
From what I can see from snippets of information, people say there aren't many differences between the PRA and PRB ECUs, mainly the O2 sensor wiring. Does this mean that if I rewire the Rywire's O2 wiring to PRA configuration, all will be fine?
Have fired it up many times as it is, so obviously the fueling / power / engine crank must all work. The engine revs, rev counter works. I do get a MIL light come on, but guess this is the O2 sensor issue.
Have a KPro4 PRA ECU ready to fit so I can read my own fault codes and do any investigation prior to taking for a dyno session, but don't fancy cooking that if there are significant issues with my current setup.
Any PRA ECU based information much appreciated!!!
Re: PRA vs PRB ECU Differences
The PRA ECU can only run a narrowband sensor. The PRB can run a factory wideband sensor.
R23AOU
Post by R23AOU »
Spunkster, thanks for the reply.
From what I can gather from looking at pinouts I have found for the PRA and PRB ECUs, all I need to do is take the wire out of Pin 16 on my "A Connector" and terminate it into Pin 4 of my "E Connector". Once I get my pins through the post I'll give this a go. If it doesn't flag an engine fault with my K100 ECU, I'll plug my KPro one in and see what faults are present and take it from there.
Hopefully this will work. When I read that the Rywire chassis harness was for an RSX/EP3, and needed an 02-04 RSX Primary O2 sensor, I just assumed it was a different connector and that was about it.
All else fails I can butcher a UK EP3 chassis loom from eBay, just wont look as neat in the end.
