FG2 2008
Firsttime007
FG2 2008
Post by Firsttime007 »
Running very lean and right now my car isles too low (under 800) and occasionally stalls out on me when cold. Live in North Carolina, NA.
Mods: Skunk2 Alpha Header, Skunk2 Exhaust Megapower RR, Hybridracing Cold air intake.
Datalog of some driving, idle, and a pull or two.
Re: FG2 2008
Have you discussed this issue with your tuner?
Firsttime007
Re: FG2 2008
Dont have a tuner. Im running the Civic-si RRB-5-SkunkHdr basemap. Runs fine. Mainly only problem is when im not using the throttle.
Re: FG2 2008
It sounds like it needs to be properly tuned and then it will run correctly.
